Home > Directory > Couplings & U-Joints
Get Listed for FREE!
Bellows Couplings Blindmate Coupling C-V Joints-Driveshafts Clutch Couplings Composite Disk Couplings Composite Shaft Couplings Curvic Couplings Diaphragm Couplings Disc Couplings Elastomeric Couplings Flexible Beam Couplings Flexible Metallic Couplings Flexible Nonmetallic Couplings Flexible Shafts Fluid Couplings Gear Couplings Grid Couplings Magnetic Couplings Metal Beam Couplings Metal Bellows Couplings Rigid Couplings Rubber-in-Shear Couplings Servo Couplings Shaft Couplings Spider Couplings Taper Bushes Torque Limiting Couplings Torsional Couplings Universal Joints Wrapped Spring Couplings
Atlanta Gear Works
Atlanta Gear Works is a total-solution industrial gearbox design, engineer, manufacture and repair company headquartered in Dawsonville, Georgia. For more than 30 years, we have served the pulp-and-paper, power, plastics, steel and chemical industries with high-quality innovative solutions and 24/7 responsive service. We repair all brands of equipment and can reverse engineer all components to equal or better quality. In addition to our state-of-the-art facilities, we offer a complete range of field services including field machining, inspections, gearing and gearbox repair for gears ranging from the simplest to the most complex. We continually invest in our people, plant and processes with the sole goal of eliminating or minimizing customer downtime.
B & R Machine and Gear Corp.
Bevel Gears India Pvt. Ltd.
Bevel Gears (India) Pvt. Ltd. located at Bangalore, India is the industrial bevel gear manufacturing arm of Jamal Group, which has 3 distinct divisions. All divisions are equipped with brand name machines, predominantly Gleason and Klingelnberg.
Precision forging of straight bevel differential gears, helical gears, diff lock clutches and other powertrain parts all fully machined to customer specifications. Precision forged bevel teeth require no other machining on the tooth profile and we are capable of forging to as low DIN 7 and its AGMA equivalent.
DieQua Corp.
DieQua Corp. provides more than just gearboxes; we provide the engineering partnership needed to optimize complex machine designs. Specializing in high-precision motion control—from servo planetary reducers to complete screw jack lifting systems—we lead with a consultative approach to solve your unique torque, speed, and positioning challenges
Miki Pulley US
Miki Pulley offers design solutions for a wide range of motion control applications. Our global network of manufacturing facilities and sales/distribution offices ensure prompt and reliable technical assistance in the U.S. and around the world. Miki Pulley collaborates with design engineers to identify the most cost effective solutions for motion control and mechatronic applications.
Nordex, Inc.
R+W America
Over the past 25+ years R+W has developed into a world leader in precision shaft couplings for torsional rigidity, vibration damping, and overload protection. Whether for micro motors or 10 megawatt drives, R+W couplings are customizable for most applications, while many standard models ship from stock. Configurable CAD models are available in a large number of file formats at www.rw-america.com
Regal Rexnord
Regal Rexnord is a major producer of mechanical power transmission drives, components and bearings, serving a wide array of machinery-intense industries, including forestry and wood products, mining and quarrying, power generation, and heating and ventilation.
SDP/SI – Stock Drive Products/Sterling Instrument
SDP/SI - Stock Drive Products/Sterling Instrument is a U.S.-based manufacturer of power transmission and motion control products, serving customers since 1950. The company specializes in precision gears, high-quality mechanical components, gearboxes, and the assembly of both mechanical and electromechanical subassemblies. SDP/SI is part of the Designatronics family of brands, offering a wide range of stock mechanical component options and customized solutions to meet diverse engineering needs.
U.S. Tsubaki
The Tsubaki brand has been globally recognized for its superior power transmission and motion control products. Since 1917, The Tsubakimoto Chain Company, headquartered in Japan, has been moving the needle forward by constantly innovating new products and expanding its global operations.
Zero-Max
Since 1949, Zero-Max, Inc. has created innovative solutions to motion control problems worldwide. With strategic distribution points located throughout the world, Zero-Max can deliver your motion control solution. The Zero-Max team of application specialists can engineer a solution to meet your motion control requirements.
Accent Bearings Co. Inc.
Accurate Gear and Machine, Inc.
Acorn Industrial Services Ltd.
AGI Automation Components
AIMS Industrial Supplies
AISCO Industrial Couplings
All-Pro Fasteners, Inc.
Ameridrives
AmTech OEM
Applied Dynamics
Applied Power Solutions
Area Distributors Inc.
Artec Machine Systems
Axu s.r.l.
Baart Industrial Group
Baker Bearing Company
Bartlett Bearing Company, Inc.
Bearing Engineering Company
Bearing Service Company
Belden Universal
Bervina Ltd.
BFK Solutions LLC
Bibby Turboflex (A Regal Rexnord Brand)
Boneng Transmission USA LLC
BRECOflex CO., L.L.C.
BSF, Inc.
C R Products Ltd.
C-B Gear & Machine, Inc.
C-Flex Bearing Co., Inc.
Canto Engineering Company
Cascade TEK
CCTY Bearing
CENTA Power
Chengdu Talent Industrial Co., Ltd.
Cold Forming Technology
ComInTec
Cross + Morse
David Brown Santasalo
DePe Gear Company Ltd
Desch Canada Ltd.
Diaphragm Direct
Distag QCS
Dorris Gear Drives
Drive Lines Technologies Ltd
Duff Norton Australia
Dura-Bar
Elliott Manufacturing
Eltool Corp.
Engineered Tools Corp.
Fellows Machine Tools
Flexocon Engineers Private Limited
Flux Drive Inc.
Formsprag Clutch (A Regal Rexnord Brand)
G.L. Huyett
GAM Enterprises
Gayatri Gear Industries
Gear Master Inc.
Hayes Manufacturing Inc.
Hoffmann Filter Corporation
Huco (A Regal Rexnord Brand)
HVH Industrial Solutions
Industrial Spares Manufacturing Co.
Inertia Dynamics, Inc.
Involute Powergear Pvt. Ltd.
jbj Techniques Limited
KBK Antriebstechnik Gmbh
Kraft Power Corporation
KTR Corporation
Logan Clutch Corp
Mach III Clutch Inc.
Magnetic Technologies Ltd
Marine Specialties, Inc.
Martin Sprocket & Gear
Master Bond, Inc.
MasterDrive, Inc.
MAV S.p.A.
Mayr Corporation
MES INC
Metal Powder Products
Minsk Gear Works
Moventas Ltd.
MW Components
NDE Clarke Pitchline Ltd
New Power Electric (USA) LLC
Nu-Teck Couplings Pvt. Ltd
OEP Couplings, a Division of Oren Elliott Products
Ondrives US Corp.
Orttech
P.T. International Corp. (PTI, A Solve IMG Brand)
Pacific Industries
PIC Design
Pinpoint Laser Systems
Pix Transmissions Limited
PTG Holroyd
Radicon Drive Systems, Inc. (Elecon)
René Baer AG
Renold Ajax
RGW Sales Canada
Ringball Corporation
Ringspann Corporation
Rowland Co., The
Rubena a.s.
Ruland Manufacturing Co., Inc.
SEPAC Inc
Servometer / MW Components
Shreecon Gear
Simply Bearings Ltd
SIPCO
SKF USA Inc.
Sprockets Australia Pty. Ltd.
Stoffel Polygon Systems, Inc.
Supreme Gear Co.
TB Wood's (A Regal Rexnord Brand)
Tien Yi Gear Works Co.,Ltd
Timothy Holding Co., Ltd.
TSS Rotterdam B.V.
Tsubaki of Canada Limited
Turbo Hydraulic Coupling Co.
TVT America, Inc.
Twiflex Limited (A Regal Rexnord Brand)
Twin Spring Coupling LLC
Venture Mfg. Co.
Voith Turbo Inc
WEG Cestari Redutores
Wellman Wacoma Limited
Wittenstein
WMH Transmissions Ltd
Xtek, Inc.
Yogi Bearings
York Industries
ZRIME
