Stafford Manufacturing Introduces Shaft Collars and Mounts
Shaft collars and mounts that can be adjusted without tools, plus handles and thumb screws to convert standard shaft collars to quick-adjust types, have been introduced by Stafford Manufacturing Corp. of Wilmington, MA. Stafford Quick-Adjust Products feature the Flip-Lok with a split hub and an integral adjustable clamp, Staff-Lok Lever-Actuated shaft collar, and the Python Flange Mounting Collar with a 6-hole bolt pattern and keyway. Suitable for a wide range of linear and low RPM rotary applications, these quick-adjust products can be easily repositioned by hand without tools.
Available in inch and metric bore sizes from 1/2" to 2-1/2”, depending upon product, Stafford Quick-Adjust Products are made from aluminum anodized black and can be supplied as specials in colors or made from steel and stainless steel with modifications to OEM requirements.
For applications using rope, the SlipKnot is molded from ABS plastic and allows for precise location as a grip, locator, or stop. Stafford Quick-Adjust Products, Grip and Go Handles, and Thumbscrew knobs are priced depending upon configuration and quantity.
