WFL at CIMT Beijing
At the CIMT 2023, which takes place from April 10th–15th, WFL will present its technology and software solutions, such as WFL iControl, scanning technologies, or the new operational data acquisition system myWFL. But that is not the end of the story. The actual highlight of the show is the presentation of the M30 Millturn and a machining demonstration of a roots rotor.
The little one for everything
The multifunctional turning-boring-milling center M30 Millturn allows complete machining of complex shafts and chuck parts with a swing of up to 520 mm and machining lengths of up to 2,000 mm. It can thus function as a lathe, a 5-axis machining center, and if needed as a gear-cutting or deep-hole drilling machine.
Complete machining at the highest level. WFL presents the highly dynamic M30 Millturn at the CIMT in Beijing. The machine handles working lengths up to 2,000 mm and a turning diameter up to 520 mm.With this machine, the focus lies on the improved design of various machine components and further increases in reliability. Thanks to the diverse range of innovations and modernizations in the areas of functionality, ergonomics, and optimized serviceability, the smallest WFL Millturn is a powerful complete machining package that is available at a very attractive price.
The machine casing is equipped with large windows to ensure optimum visibility of the working area. Special attention must be paid to user-friendly access to the tool magazine (from the front via the large sliding window). Another advantage is a state-of-the-art robust NC drive for the steady rest slide. The machine base guarantees quick set-up and repositioning of the machine. Talking about user-friendliness: within the working area, integrated LED lamps provide long-lasting lighting.
Rotor scanning
