Feature Articles
February 26, 2025
Gottfried Klein
The Tools Essential to Power Skiving
Cutting tools and strategies hold the key to maximizing machine performance across the application spectrum
The rise of power skiving to a preeminent cylindrical gear cutting process has been one of the gear industry’s most compelling success stories in recent decades. What began many years ago as a promising, but specialized, cutting process alternative for cylindrical gears with challenging interference contours is now exceeding performance and application expectations across the board. A multitude of machine solutions have sprung up seemingly overnight, from dedicated machines to universal 5-axis machining and turning centers, for soft cutting and hard finishing of internal and external gears ranging from fine pitch modules of just 0.2 or smaller, to module 9 mm or greater, as well as for machining shafts, worms and special profiles such as splines or cycloidal gears. The process, depending on application parameters, has proven to be many times faster than shaping, much more flexible than broaching and, in some cases of external gears with small overrun space, can even outperform hobbing. Power skiving can now be applied to greatly improve the productivity of cutting everything from small, complex, high-precision gears for electromobility or robotics, to larger gears, where cycle time savings can add up quickly and quality parameters have never been higher.
Now, if only it were that simple! There’s a reason this process, more than 100 years old, languished on the gear production sidelines for so many years. The best possible result can only be achieved with a particularly rigid machine and drive line that, as a whole, delivers the necessary stiffness. Furthermore, the process works best in a complete system all working in concert: process simulation, production machine, metrology support, workholding, and—of course—the cutting tools.
Tooling Up for Optimum Results, Small or Large
Identifying the optimum cutting tools for power-skiving applications is of critical importance. Simulation software, whether proprietary or “off the shelf,” enables the end user to simulate the entire skiving process in advance—an indispensable first step to determining the most effective process strategy and tool design. The simulation software analyzes the impact of various tool geometries and process parameters on chip formation, gear cutting quality and the collision situation, as well as effects on cycle time. Gleason has, through long experience and considerable application expertise in the field, been a pioneer in the development of conical and cylindrical cutting tools ideally suited to meet the challenging requirements of power skiving. When coupled with a suitable machine, the performance results are very impressive. Here are two recent, real-world application examples of power skiving tools at work, and how customers have benefited.
Simulating the power skiving process is a vital first step that helps determine the most effective process strategy and tool design
Simulating the power skiving process is a vital first step that helps determine the most effective process strategy and tool design.
Example 1: Internal Gear, Fine Pitch
(0.25 mm Module)
The workpiece in this case is a “strain wave” cylindrical internal gear, with 320 teeth, cut on a Gleason 100PS Power Skiving Machine. Strain wave gears are commonly used in industrial robots where backlash-free, very high precision performance is of the utmost importance. This particular workpiece consists of an internal gear, which meshes with a flexible cylinder with an external gear. The internal gear is an excellent candidate for power skiving. While the external meshing gear can be hobbed, a shaping operation would typically be used to produce the internal gear teeth. However, in the case of this small-module internal gear with a high number of teeth, power skiving proved to be the perfect alternative to achieve significant improvements in productivity and quality. For this application, Gleason provided a conical, solid-carbide tool with AlCroNite Pro coating. The tool featured quality AA, 163 teeth, designed for a 10-degree cross-axis angle. The power skiving application resulted in a total cutting time of just 0.6 min, performed in four cuts. Gear quality was exceptional as well: an IT5 acc ISO 1328 was achieved, with most criteria even better. Note that, with the solid-carbide tool, resharpening and recoating can be used, extending tool life to the point where the profile no longer meets the requirements.
Example 1—Conical, a solid-carbide tool with AlCroNite Pro coating for power skiving of strain wave gears in robotic drives. Cutting time is just 0.6 min—much faster than conventional shaping
Example 1—Conical, a solid-carbide tool with AlCroNite Pro coating for power skiving of strain wave gears in robotic drives. Cutting time is just 0.6 min—much faster than conventional shaping.
Example 2: Large Internal Gear
(9.5 mm Module)
Power skiving of internal gears with modules 2–4 mm is reasonably common today. For larger modules, however, profile milling or shaping is still considered the norm. However, this recent example—an internal gear, 60 teeth, 600 mm in diameter, module 9.5 mm—demonstrates how the power skiving process is inherently faster than traditional processes for soft cutting of workpieces this large, or larger. In this case, the power skiving time was just 45 minutes, as compared with profile milling (approx. 65 minutes) and shaping (approx. 290 minutes).
Example 2—A two-step process using a carbide-inserted roughing tool (left) and a solid PM-HSS finishing tool (right) delivers much faster cycle times with very low tool cost vs. profile milling or shaping operations typically used to produce an internal gear of this size (9.5 module)
Example 2—A two-step process using a carbide-inserted roughing tool (left) and a solid PM-HSS finishing tool (right) delivers much faster cycle times with very low tool cost vs. profile milling or shaping operations typically used to produce an internal gear of this size (9.5 module).
For this application, Gleason chose to optimize the process in two steps: 15 roughing cuts with a carbide-inserted tool in quality B and then finishing with a solid PM-HSS quality AA cutter. Both cutters featured AlCroNite Pro coating. Additionally, the Gleason 600/800PS Power Skiving Machine was equipped for automatic tool change between roughing and finishing cuts.
Why a two-tool process? It delivers the lowest tool cost and improves cycle time. Tool wear during roughing is high, so instead of using an HSS tool which needs frequent reconditioning, a carbide-inserted tool is used so that carbide inserts can be quickly exchanged in-house. This carbide-insert roughing cutter also delivers high roughing speeds of 120 meters per minute. Conversely, tool life of the HSS tool is much higher when finishing only, thus requiring reconditioning less often. With the HSS, AlCroNite Pro coated finishing tool, three finishing cuts are made: the first in double-flank cutting mode to remove most of the material from both flanks simultaneously, and then the last two single flank cuts, removing minimal material for the best possible quality and implementing potential flank and profile corrections.
It is also interesting to note that deburring could be done completely on the machine. For deburring of the lower face, the back side of the teeth on the finishing cutter could be used. The burr is removed with a cutting motion away from the tooth gap in the direction of the tooth so that no burr remains bent back into the tooth gap.
This two-tool power skiving strategy results in lower tool cost per gear and a competitive cutting time. Despite a total cycle time of just 46 min (including automatic change of cutter between roughing and finishing and automatic workpiece change) very good quality is achieved; with IT5 acc. to DIN 3962 for profile and lead and single pitch error. Run out and accumulated pitch error is largely dependent on pre-machining quality.
Summary
Consider the benefits of sourcing your power skiving tools from an expert company. Gleason power skiving tools are designed, manufactured, and supported by facilities in the US, Europe, and Asia. They are compatible not only with Gleason’s complete PS series of Power Skiving Machines but also with non-Gleason dedicated and universal machines. These two tool examples exemplify the opportunities available to gear manufacturers today to enhance productivity, reduce tool costs, and achieve high-quality gears by employing the right tools and leveraging this remarkable process.
gleason.com/ps
