Warning: getimagesize(https://ik.imagekit.io/agmamedia/gt/images/article_legacy_id_11838_featured_image.jpg): Failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /home/nbd2496/powertransmission.com/article.php on line 101
Warning: Trying to access array offset on false in /home/nbd2496/powertransmission.com/article.php on line 102
Warning: Trying to access array offset on false in /home/nbd2496/powertransmission.com/article.php on line 103
Ransohoff Offers LeanJet RT Cabinet Washer
The patented LeanJet RT from Ransohoff is one of a series of "Right Sized" and "Right Priced" cabinet type parts washers specifically designed for use within lean or cellular manufacturing processes. The patented rotary-pocketed wheel design eliminates work passage openings, preventing cross contamination between stages in addition to providing a unique inner stage part rotation feature that ensures optimal cleaning and drying results.
This cabinet washer is available with various wheel configurations providing both, wash and dry or wash, rinse and dry capabilities. A wide range of part sizes, weights and configurations can be accommodated. Unsurpassed cleaning and drying performance is accomplished utilizing strategically positioned high impact sprays and an efficient high pressure-high velocity heated air blow-off system. Because of its reduced footprint and high flexibility, this spray washer can be easily integrated into small footprints work cells.
