Automation Motion Control Drive Systems Drives Gearboxes Product News
Neugart Introduces New Rack-and-Pinion Drive Systems
The three components mesh seamlessly and ensuring smooth running, maximum feed force, and precise positioning accurately - crucial properties for modern automation and drive systems.
The racks are available with either straight or helical gearing and are made of induction-hardened, quenched and tempered steel. They cover a module range from 1.5 to 5 mm and comply with quality level 6. Subsequent heat treatment and precision grinding of the gearing ensure high surface quality and a long service life. In addition to standard lengths of 1,000 mm and 2,000 mm, customer-specific lengths are also available.
Thanks to its high precision and flexibility, the integrated drive unit can be used in a wide variety of applications. Matching pinions are available for gearboxes of frame size 060 to 200. These include coaxial and right-angle gearboxes in both shaft or flange designs. The Precision Line offers maximum positioning accuracy, while the Economy Line provides robust and economical solutions for standard applications.
A special feature is the gearbox's heavy-duty output shaft bearing. It reliably transmits high radial and axial forces, even under dynamic cycles and heavy loads. This results in smooth, low-noise power transmission, improved process quality, and stable system acoustics.
With the integrated gearbox-pinion-rack combination, Neugart offers a readily available system solution from a single source. It enables simple integration, high power density, and maximum flexibility, setting new standards for precise and efficient rack-and-pinion drives in modern machine and automation applications.
neugart.com
This article appeared in the February 2026 issue.
