Miki Pulley Offers BXW Power-Off Engaged Brakes for Conveyor Applications
Miki Pulley announces successful multiple conveyor line applications for its latest model BXW power-off engaged brakes. These brakes are designed to halt a motorized conveyor roller when system power is dis-engaged.
These new BXW brakes are Spring Actuated Electromagnetic Brakes. They provide reliable dynamic braking when conveyor power is disengaged and excellent performance for longer-term holding requirements for staging, loading and unloading conveyor operations.
BXW brakes utilize internal compression springs to provide power-off, fail-safe braking. The primary moving part in this robust but simple brake design is the armature plate.  When actuated, the brake compression springs push the armature plate into the friction disc when power is disengaged. This feature provides fail-safe braking and allows the brake to maintain position over long periods of time, thus preventing a conveying system from “coasting” when powered off.
Another important feature, Miki Pulley BXW Brakes function at full torque rating “right out of the box” so no startup run-in is needed. They are available in three different models for either single use braking, holding or both braking and holding. Depending on size selected, BXW Brakes are ideal for small and large applications including use with servo motors.
Additional features include: quiet operation, high holding torque, space saving, long service life, stable, reliable braking power and manual release mechanisms.
