Bearings Shafts Product News Gear Design Gearbox Design Software
KISSsoft Supports Parametric Analysis Through its Integrated Scripting Language
Parametric study is a common practice in engineering calculations. It involves changing different parameters in the model and investigating their influence on the final results of the calculation. Parametric analyses are usually carried out by means of some kind of scripting or programming language. KISSsoft supports parametric analysis through its integrated scripting language or a COM interface, which is compatible with popular programming languages such as Python, Visual Basic, and others.
In addition to many other variables already available via COM interface and SKRIPT, KISSsoft introduces the ability to modify shaft geometry, forces, and bearings by calling the special function SetElementData (elementName, parameterName, newValue). This enhancement significantly simplifies the variation of any parameter in the shaft model. A typical application is, for instance, the evaluation of how bearing position influences the rolling bearing rating life, as well as an analysis of the effects of clearance or preload on it. The results can be written in an external file, making them easily accessible to third-party applications.
kisssoft.com
