Industrial Automation Integrity
Gearmotor Trends and Topics 2024
Bonfiglioli displayed its latest gear technology during SPS Italy 2024.
Truth be told, there are few components as versatile as the gearmotor. We find them in AGVs, AMRs, and robotics. They can also be found in automation equipment, industrial drive solutions and material handling applications. Four key trends involving gearmotors today include the simplification in design and installation, quiet and energy efficient performance, predictive maintenance and condition monitoring—and lastly—the ability to perform at the highest levels in hazardous and demanding applications.
Streamlined Operations
Bonfiglioli’s AxiaVert is a series of frequency inverters offering integrated functional safety, precision and control for any industry and process. Highly dynamic and extremely performing, AxiaVert ensures complete flexibility and supports a wide range of Ethernet fieldbuses. At SPS Italy 2024, AxiaVert was featured in two hybrid systems. In the first one it was combined with a BMD servomotor, in the second one with a BMS servo gearmotor, both characterized by the innovative single-cable technology and both managed in PTP or Master/Slave operating mode. The high resolution of the enconders used on BMD/BMS motors allows to achieve an infinitesimal precision positioning and therefore, it represents the best choice for challenging applications, above all in motion, labelling and filling fields. The most important innovation is represented by the shielded single cable applied to the servomotors, which represents a huge advantage in terms of simplification during installation and space saving: one single cable means one single connector, i.e. one single attachment point upstream with the drive and downstream with the servomotor.
In the field of mobile robotics applications, Bonfiglioli displayed BlueRoll: the high-performance, wheel-mounted gearmotor platform for AGVs and AMRs, featuring an ultra-compact and energy-efficient design for a long operating cycle. The modular drive system is available in three configurations, basic, advanced and compact, with a customizable single gearbox load ranging from 360 to 1,020 kg and a maximum speed of 2 m/s. A compact servo gearmotor of the BMS Series, together with a combined solution composed of a TQ high precision planetary inline gearbox of the Performance Line and a BMD permanent magnet AC low voltage synchronous motor, were also showcased at the booth.
The BMS Series’ main advantages are excellent compactness, high torsional stiffness and low moment of inertia, making it the ideal solution for applications that require highly precise positioning, accuracy and efficiency. Thanks to its space-saving machine design, along with a wide range of options, the BMS Series enhances performance through the synergy between permanent magnets, synchronous motors and precision planetary gearbox technologies. According to the application requirements, in terms of speed torque and operation cycle, it is also possible to select the suitable gearmotor choosing between the base, medium or high overspeed variants.
