IMTS 2016: Oelheld U.S. Inc. (N-7475)
SintoGrind IG 540
Oelheld's SintoGrind IG 540 grinding oil is designed for flute grinding, profile grinding and outside and inside diameter grinding. SintoGrind IG 540 works on a wide variety of materials including tungsten carbide, HSS, PCD, CBN, cermet and ceramics.
Features of the SintoGrind IG 540 include protection against cobalt leaching, low foaming, high-quality surface finish, superior ageing, excellent flushing and cooling properties, low evaporation and misting and a high flash point. The SintoGrind IG 540 is also physiologically safe and is designed to have a pleasant odor.
ToolGrind TC-X 620
Oelheld has introduced ToolGrind TC-X 620 as its high performance grinding oil. ToolGrind TC-X 620 incorporates the additive technology from Oelheld's flagship product SintoGrind. The product is designed for flute grinding, profile grinding and outside and inside diameter grinding. ToolGrind TC-X 620 works on a wide variety of materials including tungsten carbide, HSS, PCD, CBN, cermet and ceramics.
The TC-X 620's features are identical to the IG 540's:protection against cobalt leaching, low foaming, high-quality surface finish, superior ageing, excellent flushing and cooling properties, low evaporation and misting and a high flash point. The ToolGrind TC-X 620 is also physiologically safe and is designed to have a pleasant odor.
SintoGrind TC-X 630
SintoGrind TC-X 630 is designed to be Oelheld's new entry level product to its flagship SintoGrind series. SintoGrind TC-X 630, with its new base oil technology, is designed for flute grinding, profile grinding, and outside and inside diameter grinding.
SintoGrind TC-X 630 works on a wide variety of materials including tungsten carbide, HSS, PCD, CBN, cermet and ceramics. SintoGrind TC-X 630 was especially formulated for demanding grinding tasks and delivers exceptional feed and speed rates with superior surface finish. Its lubricity lends to extended wheel life and minimal heat build-up, which in turn eliminates surface cracks and burns.
