IKO Linear Motion Rolling Guides Address Battery Manufacturing Challenges
As new electric vehicle (EV) advancements drive investments in an automated production infrastructure, there are aspects of EV manufacturing in which specifying an appropriate motion component requires particularly careful consideration. That’s because the heart of the EV — the lithium-ion (Li-ion) battery — poses safety and performance risks that you must keep in mind when selecting motion components. To minimize these risks, it’s important to partner with a supplier that can help you select an appropriate device and offer modification options to meet the distinct requirements of Li-ion battery manufacturing processes.
Although copper is commonly used in Li-ion batteries, its hard-to-detect particles can contaminate the electrode and cause dangerous internal short circuits. Components used in Li-ion battery production should be free of copper-based substances and must not generate dust or dirt. In addition, moisture and humidity hinder Li-ion battery lifetime and performance. Here’s an overview of how these environmental concerns affect component selection, along with the characteristics your motion components will need in Li-ion battery production:
- Prevent contamination from copper-based metals. Because inspection does not always find copper-based metals that may cause internal short circuits or thermal runaway, it’s important to look for bearings and other components — including the lubricating greases you use with them — that do not contain these metals.
- Moisture and humidity mitigation. Lithium reacts to moist, humid conditions inside the production area, transforming itself to lithium hydroxide and hydrogen. This reaction severely affects the battery’s charging capacity and performance, durability and, ultimately, reduces its lifetime. Li-ion batteries are manufactured in a low dew point environment where moisture is almost zero.
- Eliminate dust and dirt penetration. In addition to the safety risks posed by Li-ion battery combustion, impurities that enter cells and electrodes can hinder ion flow inside the battery and affect its performance and lifetime. Contaminants may also lead to voltage failure.
The good news is that linear guides can function reliably in challenging environments — such as Li-ion battery manufacturing — with careful selection, protection, and proper lubrication. IKO has extensive expertise and a wide range of protective accessories available to create a custom product that will perform trouble-free.
For example, the Linear Way and Linear Roller Way lineup of linear motion guides includes products with stainless steel-made parts, and we also offer stainless steel crossed roller bearings upon request. Stainless steel is copper-free and desirable where rust prevention oils or dust-generating greases cannot be used.
Here’s how to customize IKO linear motion guides to meet the special requirements of automated Li-ion battery manufacturing operations:
Low dust generation greases
