Heidenhain Introduces Encoders for Small Motors
With the introduction of the PressFit rotary encoders from Heidenhain, small-motor manufacturers finally have a better solution for incorporating automated mounting for feedback devices. This new ExI 11xx encoder series features a unique compact design that allows fast and simple mounting by press-fitting into a motor housing while still allowing surrounding space for cables and seals. Heidenhain’s PressFit encoders are made for integration into motors with a flange size as small as 40 mm x 40 mm or an axis height of only 20 mm.
Developed in collaboration with global motor manufacturers, Heidenhain’s new PressFit encoders include a “PressFit” flange that can be secured in a motor housing through a frictional connection, using a specially designed tolerance sleeve. This innovative system promises to support automation efforts by easing mounting requirements, leading to less mounting time being required.
