Graphalloy Bushings Provide Solution for Oil Field Applications
Graphalloy wear rings and bushings from Graphite Metallizing Corporation provide performance superior to standard metal stationary and rotating wear parts in pumps for CO2 service in oil field applications. Self-lubricating Graphalloy, a graphite/metal alloy, eliminates concern about bearing failures or possible flashing of CO2.
The ability to operate without additional lubrication is important in CO2 injection applications because CO2 has low lubricity. Standard metal wear parts rely on the lubricity of the liquid being pumped for proper operation so they are prone to failures in pumps used to inject CO2. In addition, due to high suction pressure required to keep CO2 as a dense phase liquid, flashing is always a possibility.
CO2 injection in older, low flowing wells is becoming an increasingly popular method for permeating rock formations and forcing more oil to the surface. Many older wells still contain vast amounts of oil locked in the pores of rock layers deep underground. CO2 injection often releases more oil in older wells than can be released by water injection.
"Use of self-lubricating, non-galling Graphalloy materials in pumps for CO2 service provides substantial cost savings by avoiding expensive downtime and field repairs caused by wear part failures," said Eben Walker, General Manager of Graphite Metallizing Corporation. "Graphalloy is currently the material of choice for many oil field applications in North America and around the world."
