Zero-Max Releases ETP Power Shaft Bushings
ETP Power keyless shaft locking bushings feature fast mounting with high radial load capacity. They are suitable for locking into position rollers in automated radiator manufacturing lines (photo) as well as gears, pulleys, sprockets and other components in automated machinery. Handling torque ranges from 531 to 10,620 inch lbs. (60 – 1,200 Nm), these ETP Power shaft locking bushings from Zero-Max provide the highest radial load performance within the single screw ETP product line.
The ETP Power single radial screw design ensures fast mounting, repositioning and phasing of the components to the shafts.ETP Power positions in seconds and can be readjusted hundreds of times just as quickly and without any axial movement of the bushing or component along the keyless shaft. An Allen wrench is all that is required to mount and lock these bushings into place. They have sealed, clean lines that resist debris collection and clean easily without any special maintenance.
The ETP Power's single radial tightening screw provides a solid and more precise connection between shaft and hub unlike conventional shaft locking bushings. It incorporates a double-walled sleeve filled with a pressure medium. When the actuation screw is tightened, the hydraulic pressure medium in the sleeve expands the double walled sleeve, forming a very tight, continuous connection between the shaft and mounted component. The bushing aligns precisely without axial movement as it is tightened. ETP Power bushings feature a unique, single adjusting screw design and are available in 15, 19, 20, 22, 24, 25, 28, 30, 32, 35, 38, 40 mm shaft sizes.
