Winsmith Displays Stainless Steel Conveyor Drives at IPPE Show
Winsmith recently participated in the International Production & Processing Expo (IPPE) in Atlanta, GA, January 31-February 2. A manufacturer of high performance industrial gearing technologies, Winsmith displayed an upgraded stainless conveyor drive that features FDA-compliant blue plugs and a new Keyless Shaft Locking Device.
Launched in 2015, Winsmith’s new stainless conveyor drive is IP69K certified to withstand high pressure, high temperature wash down and contamination.  It is the ideal speed reducer for food processing, and demanding industry applications including fruit, vegetable, and meat processing. The stainless conveyor drive is available in five case sizes and more than 15,000 configurations. It features a single-piece design and sealed housing, facilitating easy cleaning, continuous operation and safe wash down. All lubricant and drain plugs are easily accessible for maintenance checks and have been fitted with new FDA compliant blue plugs that are both magnetic and x-ray detectable. These plugs ensure a smooth, bolt-free housing and have been pressure wash tested to 1450 psi.
The Winsmith KLD shaft locking device is an upgrade that benefits food and beverage processors who want to simplify equipment maintenance. The keyless locking system can be installed in minutes and reduces disassembly times by mitigating fretting corrosion, as well as downtime for field servicing.
