Weiler Abrasives Introduces Tiger 3D MAX Ceramic Flap Discs and Blending Discs
Weiler Abrasives announced the new Tiger 3D MAX Ceramic flap discs and blending discs, which are products built for maximum material removal, durability and consistency. This expansion of the 3D MAX lineup brings advanced precision-shaped grain technology to a wider range of grinding applications.
“Our 3D MAX technology is built to let the grain do the work,” says Michael Zulauf, product manager, Weiler Abrasives. “By maximizing the cut rate and reducing the effort required by the operator, we are helping our customers improve efficiency and consistency and reduce fatigue, all while cutting down on costly disc changeovers.”
The Tiger 3D MAX products feature 3D precision-shaped grain to help operators remove more material in less time. The grain stands upright and micro-fractures to stay sharp. The design also optimizes grain retention, which extends product life.
Tiger 3D MAX Ceramic flap discs are designed for maximum metal removal while maintaining control across a wide range of grinding and finishing applications. Flap discs are available in 4.5- and 7-inch sizes, with 7/8 open arbor and 5/8-11 hub options. Blending discs are available in both Type S and Type R style connections to allow for quick mounting and disc changes. The Tiger 3D MAX portfolio also includes resin fiber discs.
3D precision-shaped grain maximizes cut rates, enabling up to 30% faster material removal than standard ceramic grain. Optimized grain retention extends product life and reduces changeovers. A specialized top coat reduces heat buildup and glazing, protecting high-value parts from discoloration and damage. Micro-fracturing grain technology lets the grains do the work, reducing the required operator pressure and making tough grinding jobs easier. Both disc types are contaminant-free, making them safe for use on stainless steel and aluminum.
weilerabrasives.com
