Vibration Transmitter Turns Accelerometers into 24/7 Vibration Monitoring Sensors
The model 682A09 ICP in-line 4-20 mA vibration transmitter from IMI Sensors installs in line with any industrial accelerometer and converts the vibration signal to a 4.20 mA velocity output that can be trended with today's PLC, DCS or SCADA control room systems.
Installing right into the cable run, the 682A09 does not require DIN rails, cabinets or special power. Customers can take existing accelerometers and turn them into 24/7 vibration monitoring devices for critical machinery.
The 682A09 is a stainless steel, hermetically sealed design capable of operating in the harshest environments with 2-pin MIL connector input and 3-pin MIL connector output. IT accepts a 100 mV/g analog signal, converts to 4-20 mA output and operates off of loop-power supplied by the PLC, DCS or SCADA system. Also, the vibration transmitter outputs the 100 mV/g analog signal via its 3-pin output connector. The analog signal can be run to a central collection point, so users can maintain the FFT capability of the original system.
