Variation Analysis of Tooth Engagement and Load Sharing in Involute Splines
Involute spline couplings are used to transmit torque from a shaft to a gear hub or other rotating component. External gear teeth on the shaft engage an equal number of internal teeth in the hub. Because multiple teeth engage simultaneously, they can transmit much larger torques than a simple key and keyway assembly. However, manufacturing variations affect the clearance between each pair of mating teeth, resulting in only partial engagement.
