Two-in-One: CNC Precision Grind Both Worms and Gears
Manufacturing high-accuracy worm gears and screws alongside precision spur and helical gears has traditionally required the use of two quite different CNC grinding machines. Thanks to PTG Holroyd’s newly launched HG350-WG worm and gear grinding center, however, just one machine can now complete both tasks.
“Since the launch of our HG350-G [gear-only] grinding centre in 2021, we’ve been investigating ways of bringing manufacturers of worms or gears, or both, greater levels of flexibility and efficiency in their manufacturing processes,” comments Mark Curran, sales director of UK-based PTG Holroyd.
“The result of a £multimillion machine tool development program,” he continues, “our new HG350-WG worm and gear grinding center does just that. Taking the concept behind the PTG Holroyd HG350 range a stage further, the dual-capability ‘WG’ model has been designed not only for the one-off and batch grinding of high-accuracy worms and screws but also for precision grinding spur and helical gears of up to 350 mm in diameter. Primarily, that means significantly improved versatility for manufacturers who need to quickly switch between grinding processes. Many other businesses will now only need to invest in one type of helical grinding machine tool while, for others, selecting an HG350-WG model will mean being able to expand their manufacturing capability to either worms or gears.”
Designed from the ground up to bring greater levels of efficiency and accuracy to the production of specialized gears and tooth forms, this latest member of the PTG Holroyd HG350 family features an advanced version of the company’s acclaimed HPMS (Holroyd Profile Management System) for rapid programming and seamless background calculations of both worms and gears. In fact, operators will only need to input the profile shape and size they wish to achieve for a precise dressing path to be created.
Uses Renishaw Sprint 3D scanning probe alongside Sinumerik ONE CNC
Just like all PTG Holroyd HG350-G gear grinding machines, the new HG350-WG worm and gear variant is controlled by Siemens’ highly intuitive Sinumerik ONE which has integral safety and failsafe features, enhanced reporting of machine health and performance data, and uncompromising levels of industrial security.
