The Importance of Precision in Automation Systems
In high-performance automation systems, even the smallest components can carry significant weight. That’s a lesson one U.S.-based OEM learned the hard way when shaft collars – believed to be Ruland parts – began causing failures on packaging machines using linear actuators deployed at customer sites across Asia.
The parts matched the engineering drawing, which still listed Ruland as the source. But when the machines began malfunctioning in the field – drifting out of alignment, requiring emergency servicing, and prompting panic from end users – the OEM turned to Ruland for answers. What they uncovered was a small substitution with major consequences.
A misidentified shaft collar, a real-world failure
The problem surfaced when shaft collars began “walking” down the shaft during use, causing the actuator’s stroke to overshoot its intended limit. These collars weren’t used as hard stops, but rather as precise axial reference points. The moment the actuator reached the collar, it would reverse – meaning even small shifts in the collar position could throw the system out of spec.
When the OEM reached out to Ruland, the support team immediately noticed something was off: the collars had no bore size or manufacturer stamp. Ruland includes both on every shaft collar it ships, precisely for situations like this – ensuring traceability in the event of a failure. These parts may have looked like Ruland collars, but they weren’t.
Without part markings to confirm their origin, the Ruland team turned to the application details. It was there that the issue became clear.
Diagnosing the problem: the face of the matter
Ruland engineers asked how the collars were being used – and the customer explained their role in referencing the actuator stroke. In that type of setup, the face of the collar must be precisely perpendicular to the bore. Without that, the actuator meets the collar at an angle, creating uneven pressure on the shaft. That slight imbalance can cause the collar to move or “walk” with each cycle of the actuator.
