The Electric Motor as a Data Source
Condition monitoring starts at the motor and ends at the work order
Electric motors are critical to data center operations, powering cooling systems, pumps and other equipment.
At Automate in Chicago this June, I was asked what predictive maintenance involves and why it is happening now. When I started as an engineer designing control systems, we collected data all day long, and in many cases, we did very little with it. We had plenty of sensors and very little ability to turn what they collected into a decision in time to matter.
Computing speed, real-time data and artificial intelligence (AI) have since arrived together, and the value in motor data is now within reach for a plant of almost any size. The part I care most about has not changed. A plant can get into a loop of continuously monitoring everything, and if nobody takes the right action on what the data shows, the effort is wasted. That is how I look at condition monitoring. Start at the motor, and judge the program by what happens after the alert.
Why Condition Monitoring Should Start at the Motor
Power transmission is a mechanical world of shafts, gears, bearings and couplings, and nearly all of it is turned by an electric motor. The motor is the one component in that train that reports on itself. The equipment that starts it and protects it has to measure how hard the motor is working, every minute it runs. Every motor in a plant is a data source, whether or not anyone is reading it.
Electric motor systems account for 72 percent of industrial electricity consumption, according to the International Energy Agency’s Electric Motor Systems Annex. That makes the motor the place where a plant’s energy costs and its reliability risks meet. Ask a reliability engineer what fails first on a motor, and the answer is the bearings. It has been the answer in the industry’s reliability surveys since the 1980s.
Mechanical problems downstream of the motor change how hard the motor has to work, and the motor’s data reflects that. When a coupling goes out of alignment, or a gearbox starts to lose efficiency, the motor draws more current to do the same job. The same is true of a pump fighting a partial blockage or a conveyor with a seized idler. A trend on that data will usually show the change before a technician can hear or feel it on the machine. It works the other way too. A small voltage imbalance at the motor produces a current imbalance six to 10 times larger, and with it extra vibration, heat and wear on the coupling and the bearings.
