Stock Drive Offers Miniature Right Angle Gear Drives
A new series of miniature right angle gear drives from Stock Drive Products (ISO 9001:2000 Registered Manufacturer) features a lightweight, non-corrosive, all metal construction. They are available with single or double output shafts with ratios of 1:1 or 2:1 at a maximum rpm of 1800. Their maximum continuous hp is 1/8. Identified as the A 271A-... series, they consist of aluminum housings, hardened steel helical gears, steel shafts and brass bearings. Special options on shaft, material and ratios are available on special order. They are not intended for use as speed increasers. Panel mount versions of these miniature drives are available as the A 2Z1A- ... series.
