Star Cutter Advances Precision Reaming with New Double Pilot Reamer Design
Star Cutter Company introduces its new Double Pilot Reamer, a precision-engineered solution designed to deliver superior size control, exceptional surface finishes, and dramatically extended tool life in demanding barrel machining applications.
The Double Pilot Reamer is ideally suited for deep-hole and high precision bore operations where size, control, straightness, and surface finish are critical. Typical applications include hydraulic and pneumatic components, aircraft components, engine and powertrain parts, defense, orthopedic devices and industrial cylindrical components requiring tight tolerances over long bore lengths.
Built around a fully guided cutting approach, the Double Pilot Reamer stabilizes the tool from entry to exit, supporting it through the full length of the bore. By maintaining alignment throughout the cut, the tool minimizes deflection and vibration which can lead to inconsistent results in conventional reaming operations.
A key benefit of the new tool is one of the best reamed surface finishes available in the industry. The Double Pilot Reamer effectively eliminates chatter, scoring and witness lines, three of the most common causes of scrap, rework, and sub-standard quality in precision barrel machining.
“The performance gains with the new Double Pilot Reamer are immediate and measurable,” said Rick Rickert, Round Tool Product Manager at Star Cutter Company. “In many applications, manufacturers are seeing tool life improvements of up to ten times compared to conventional reamers, while also achieving some of the best surface finishes in the industry.”
Beyond measurable performance gains, the Double Pilot Reamer introduces a new level of predictability into the manufacturing process. With consistent results cycle after cycle, manufacturers can confidently reduce inspection time, eliminate secondary finishing operations, and keep production moving without interruption.
