Stainless Steel Miter Gears from QTC Are Stocked in 10 Sizes in Modules 1-3
Precision 20o pressure angle stainless steel miter gears from Quality Transmission Components are stocked in 10 sizes in modules 1~3 in both 20 and 25 tooth. These gears, identified as the SUM Series, are made of SUS303 and conform to precision grade JIS B 1704 grade 3 standards. They are stocked in sizes ranging from Module 1 to Module 3. Bore sizes range from 6 mm to 20 mm and hub diameters from 16 mm to 65 mm.In addition to these stainless steel miter gears, QTC stocks a wide variety of miter gears in other materials including: steel, plastic, injection molded, sintered metal, and in specialized types including: carburized & hardened, angular, finished bore, and spiral miter gear types.
At the new QTC eStore you can get immediate quotes, download 3D models, and place online orders. Go to: http://www.qtcgears.com/RFQ/default2.asp Other power transmission solutions provided by QTC include over 9,000 off-the-shelf timing belt pulleys, belts, belt and roller chain tensioners and other components for prototypes and production applications.
Complete technical specifications are contained in catalog Q420, which is available to free upon request from Quality Transmission Components, Division of Designatronics, Inc., 125 Railroad Avenue, Garden City Park, NY 11040-5016. Phone: 516-437-6700 Fax: 516-328-3343.
