Stafford Offers Line of Shaft-End Adapters
A new standard line of machinable shaft-end adapters that are offered with a plain bore or keyway and a variety of options is being introduced by Stafford Manufacturing Corp. of Wilmington, Massachusetts.
Stafford Machinable Shaft-End Adapters feature the Accu-Clamp design with an integral clamp on one side while leaving the other side fully custom-izable by the user.  Available with or without a flange, these parts can be modified by the user or by Stafford and are offered with a plain bore or keyway for greater torsional holding power and fixed shaft phasing.
Ideally suited for use in conveyor systems and special machinery, Stafford Machinable Shaft-End Adapters can be provided with options including custom bolt-hole patterns, indexers, cam profiles, milled slots, and more.  Available in aluminum, steel, and stainless steel, they come in 11 standard bore sizes from 0.5" to 2.0" I.D.
