Stafford Introduces Split Mounting Clamps
A new series of heavy-duty “L” mounting clamps that feature two-piece split construction, dowel holes for precise locating, and a large mount footprint is being introduced by Stafford Manufacturing Corp. Staff-Mount Split Mounting Clamps feature a clamping half and a perfectly flat mounting half that provides a large footprint, includes dowel holes for precise locating, and 4-hole patterns for multiple attachment options.  Strong, stable, and accurate, they have eight drilled and tapped holes to let users attach the mounting half to an object, and secure a shaft, tube, or pipe using the clamping half, or for screwing through both halves to the object.
Suitable for mounting a shaft or tube to a conveyor, machine frame, and process or packaging equipment requiring rigidity and accuracy, Staff-Mount Split Mounting Clamps are machined from aluminum and offered in standard 2” and 4” lengths with 3/4” to 2” shaft, tube, and pipe sizes; specials are available. Dowel hole locations are held to a tolerance of 0.001”. Staff-Mount Split Mounting Clamps are priced from $69.50 (list) depending upon size and quantity. Price quotations are provided upon request.
