Spherical Bearings from QBC Feature More than 100 Sizes Stocked for Precision and Commercial Applications
The new spherical bearings from Quality Bearings & Components are stocked in over 100 inch and metric sizes for both precision and commercial tolerance applications. These bearings have a spherically shaped inner ring and a cylindrical bore for shaft mounting. The outer surface of the outer ring allows for easy installation into any housing. These high capacity bearings are designed for superior performance in low frequency applications and have the ability to accommodate shaft misalignments in most styles from 8.5O to 16.0O depending on the mounting used. Their construction consists of two and four-piece types including self-lubricating models. They are designed to fit shafts ranging from .165" to 1.875" and from 5 mm to 25 mm in diameter. O.D.'s range from .4687" to 4.000" and from 5 mm to 25 mm in diameter.
Buy it
View catalog page
Request catalog
