Smalley Launches Metric Hoopster Retaining Rings
Smalley Steel Ring Company recently announced the launch of the new Metric Hoopster Retaining Rings. The new Metric Hoopster Retaining Rings offer an innovative way to retain mechanical components when space is a problem. The Hoopster’s minimal radial projection and shallow groove depth allows the Hoopster to fit where regular stamped rings and retaining rings cannot. The Hoopster’s low profile, precision circularity and small radial size allow it to be an unobtrusive component in an assembly. Hoopster Retaining Rings are suitable for light to heavy loads and are ideal for thin wall tubes. An additional advantage of the Hoopster is its potential for high thrust capacity. The low radial profile will not twist or deform under load as with conventional retaining rings. As an extension to Smalley’s popular Hoopster Retaining Rings, the new metric series offers engineers added design flexibility. Over 150 new rings are available from 10 mm to 76 mm in carbon and 302 stainless steel. Hoopster Retaining Rings are easy to install and remove without any special tools. Specials can be made with No-Tooling-Charges. Internal housing rings are available with an optional bent end (removal provision) to simplify the process.
