SKF DryLube Bearings Designed for Extreme Temperature Environments
SKF DryLube Bearings eliminate any need for grease relubrication and are designed to perform reliably and virtually maintenance-free over a wide temperature range.  These next-generation high-temperature bearings especially suit hostile and extreme temperature applications, including equipment used in the metal and steelmaking and food and beverage industries, among others.
SKF DryLube Bearings are filled with a dry lubricant based on graphite or molybdenum disulfide and a resin binder.  The dry lubricant is injected into the free space of the bearing, bonded to the cage, and cured until it solidifies.  During the bearing's operation, the dry lubricant maintains a thin film on the bearing's raceways and rolling elements to protect against metal-to-metal contact and any potential damage caused by solid contaminants.
The bearings can provide effective lubrication for extreme temperature applications up to 350 degrees C (660 degrees F), achieve higher speed capabilities than standard graphite-cage counterparts, and exhibit minimal lubricant loss over time. They especially promote enhanced worker safety by reducing fire risks and eliminating slippery surfaces and can additionally help contribute to "green" operating objectives compared with many oils and greases. SKF DryLube Bearings are available in four main variants to satisfy the most demanding operating conditions of a particular application.
