Silicone Gel Base Vibration Mounts From AAC Feature Superior Damping Performance
A new series of double studded silicone gel vibration mounts from Advanced Antivibration Components - AAC feature superior damping performance.
The mounts, identified as the V10Z61MSF Series, are designed for light to medium loads of from 1.25 kgf to 3.25 kgf (2.8 lb. to 7.2 lb.) up to 7.5 kgf/ to 12.5 kg/leg (16.5 lb. to 27.6 lb.) per mount. Their highest damping effect arises when the gel is compressed 10% up to 30%. An important feature of these metric mounts is their ability to operate effectively over a very wide temperature range of from -400 C to +2,000 C (-400 F to 3,920 F). They offer excellent chemical resistance and are low in compression set. Performance remains the same even after repeated use. They contain nothing harmful and are therefore considered environment-friendly. Quotes, online orders and 3-D models are available at AAC's eStore.
Additional technical specifications are contained in Catalog V100 available free upon request from Advanced Antivibration Components (AAC), 2101 Jericho Turnpike, Box 5416, New Hyde Park, New York 11042-5416. Phone: 516-328-3662. Fax: 516-328-3365. Web: www.vibrationmounts.com.
