Silicone Gel Base Vibration Mounts Feature Superior Damping Performance
A series of double-studded silicone gel vibration mounts from Advanced Antivibration Components - AAC feature superior damping performance.
The mounts, identified as the V10Z61MSF Series, are designed for light to medium loads from 1.25 kgf to 3.25 kgf (2.8 lb to 7.2 lb) up to 7.5 kgf/ to 12.5 kg/leg (16.5 lb to 27.6 lb) per mount. Their highest damping effect arises when the gel is compressed 10 percent up to 30 percent. An important feature of these metric mounts is their ability to operate over a very wide temperature range from -40O C to +2,00O C (-40O F to +3,92O F). They offer excellent chemical resistance and are low in compression set. Performance remains the same even after repeated use. They contain nothing harmful and are therefore considered environment-friendly. Quotes, online orders and 3-D models are available at the AAC eStore.
Additional technical specifications are contained in Catalog V100 available free upon request.
