SEPAC Designs Thin Spring-Engaged Brake
SEPAC designed the Thin Spring-Engaged Brake (TSEB) to provide OEMs with a thin body high-performance/low-cost spring engaged power off brake. The TSEB is 60 – 70 percent thinner and up to 20 percent less expensive than conventional servomotor type high-performance brakes. The TSEB offers reversible mounting – with the shaft extending past the brake or within the brake body for the shortest, thinnest package. The friction disc/rotor and hub are manufactured from lightweight metal, allowing for lower inertia. A splined hub for shaft connections typically provides less than 1.5° backlash.
