Same Hob for Two Gears
I make all the double helical gears that go into a gearbox - four different gears in this unit. If the gear module for the bull gear and the intermediate gear are the same (these are the two individual gears that mate), and the gear module for the high-speed pinion and high-speed gears are the same (these are the other two individual gears that mate in the gear box as well), is it then possible to just use two hobs in this setup to make all four gears, since they mate together with each other? We are currently using a different gear hob for each gear.
