Röhm Chucks Improve Part Clamping for Oil and Gas Industry Applications
In booth 1315 at Houstex 2017, Röhm Products of America will showcase two chucks that optimize part clamping specifically for applications within the oil and gas industry. On display will be the HSFZ swivel chucks that permit machining of bushings, connectors and adaptors from both sides. Röhm will also be displaying the LVE-V-AZ pneumatic six-jaw front-end chucks that enable precise, centered and productive turning of large, long pipe ends. The LVE chuck provides safe complete threading operations without the need for shimming the pipe to center.
The swivel chucks feature an axis, which is orientated 90 degrees relative to the rotary axis and swivels to automatically bring the workpiece into machining position to maximize both radial and axial accuracies and minimize setup time. In the LVE-V-AZ chuck, a combination of three concentric clamping jaws with three compensating clamping jaws ensures low-deformation clamping.
Houstex show visitors will also experience firsthand how Röhm's pneumatic 6-jaw front-end LVE-V-AZ chucks are optimally suited for machining the ends of pipes used for extracting crude oil or natural gas. For those part applications, the chucks can be mounted to the front and rear sides of the machine spindle to allow for heavy-duty chipcutting performance at high turning precision.
Röhm offers the chucks in a variety of configurations to handle a wide range of machining situations such as machining of bent pipe. The configurations include ES versions with rapid stroke and clamping stroke, versions featuring retracting clamping arms for precentering the workpiece, and versions with spring clamping and pneumatic release.
