Rexnord Introduces MCF 3000 Series Couplings
Rexnord recently announced the introduction of the 3000 series MCF coupling. MCF Couplings are used as an alternative to hollow shaft mounting options for large drive applications to simplify the assembly and maintenance of gear drives. It connects the head shaft pulley of the conveyor to the solid low speed shaft of the gear drive and transmits all of the drive torque while supporting the drive and motor assembly’s weight. The MCF is be available in both Type 2 (interference fit) and Type 4 (shrink disk hub) configurations. Designed as a direct add-on for the V-Class gear drive, the 3000 Series is a cost effective option that’s simple design makes it easy to install and remove. The all-new 3000 series offers simple design, shrink disc mounting options, the availability of RSB hubs and is designed specifically for the V-Class. Simple, cost effective, and versatile, Rexnord adds another premium quality coupling solution to its bulk material handling product portfolio.
