Revolvo Expands Range of Roller Bearings
Revolvo has expanded its lineup of roller bearings with the introduction of flange, hanger and take-up bearings. According to the company’s press release, the bearings are designed to simplify and expedite installation while cutting downtime and reducing maintenance costs.
The flange units are available in metric shaft sizes from 35 mm to 300 mm, the hanger units from 35 mm to 115 mm and the take-up units from 45 mm to 160 mm. The bearings are designed for use in applications such as quarrying, mining, steel, power generation, cement, water treatment and sugar processing.  All bearings are manufactured with a 250-grade cast iron that meets all design requirements.
