QTC Belt and Chain Tensioners Maintain Constant Tension
Quality Transmission Components has introduced a new line of belt and chain tensioners called the Zetasassi line that is designed to reduce noise, transmit torque more effectively, minimize wear and increase the belt and chain lives, according to the company’s press release.
Tension can be modified on the chain or belt with spring-loaded Econobelt tensioners made in rotational and linear movement varieties; they are easy to install and require no maintenance. According to QTC’s press release, the Zetasassi line of belt and chain tensioners result in a 23 percent increase in chain life, 7 percent reduction in vibrations, 12 percent reduction in noise and reduction in chain slackening.
To see the original press release, please visit http://www.econobelt.com/Press/Tensioners.htm.
