QBC Releases Induction Heater
A new portable Betex 22 ELD induction heater from Quality BearingsĀ and Components (QBC) designed for heatingĀ bearings, pulleys, couplings, rings, etc. so that they can easily be mounted in maintenance (MRO) and/or production (OEM) applications. The built-in LED display makes this unit very easy to use. Digital electronics ensure optimum control during the heating process. The controller automatically regulates the most efficient use of power to ensure even and rapid heating. The Betex 22 ELD is the smallest of a wide range of 12 induction heaters in both standard and turbo types. Identified as the TB-270600S, this 3.6 kva heater will accept components with a minimum ID of 10 mm (.39") and a maximum OD of 240 mm (9.45"), plus a maximum width of 120 mm (4.72"). The maximum weight of the component to be heated is 15 kg (33 lbs.). Various accessories are available.
