Pro Series CNC Router Produced for Panel Process Manufacturing
Techno, Inc. introduces the Pro Series CNC Router to its product line of CNC machining solutions. Designed to meet the high demands of panel process manufacturing, the Pro Series is constructed of large, heavy tubing that is both welded and stress-relieved. The router is also comprised of precision ball screw drives on all three axes, THK rails and bearings as well as high-speed, closed-loop servomotor and drives.
Techno's New Pro Series is available in a variety of standard sizes ranging from 4 ft x 8 ft through 6 ft x 20 ft. "We are welcoming special sizes and customization requests with this model because we understand that size and usage vary from shop to shop," says Roy Valentine, CNC router sales manager. "The Pro Series machine can be equipped with a variety of spindle options including automatic tool changer, collet spindles, drill banks, or multi-spindle setup for high volume part production. Multiple zone vacuum table, reverse engineering lasers, and fourth axis rotary tables are just some of the additional accessories compatible with this new machine."
Additionally, the New Pro Series machine features a CNC Servo G-Code Interface that is both easy to learn and operate. This Windows-based interface is a comprehensive CNC program that includes features such as toolpath preview with viewing tools and adjustable screens, built in G-Code editor, machine speed and spindle rpm override, X/Y axis orientation swapping, program skip ahead (in case of tool breakage), built in basic nesting and production logging.
