Plastic Shaft Collars Match Processing Requirements
Custom shaft collars machined from various thermoplastics to match process applications requiring chemical resistance and frequent washdowns are available from Stafford Manufacturing Corp.
The Stafford Plastic Clamp-Type Shaft Collars are offered in one- and two-piece styles and are supplied with stainless steel clamping screws for use in FDA- and USDA-approved processing equipment and conveyors. They are machined from Teflon, Delrin, nylon and other thermoplastics, so designers can specify collars that precisely match other system components.
Available in one to four-inch ID bore sizes, the Plastic Clamp-Type Shaft Collars are appropriate for applications requiring chemical resistance and/or frequent wash-downs, such as food and pharmaceutical processing. Stainless steel, steel and anodized aluminium collars are also available.
The Plastic Clamp-Type Shaft Collars are priced according to material, size and quantity. Samples and price quotations are available on request.
