Plastic Ball Bearings from QBC Feature Glass or 316 Stainless Steel Balls
Plastic plain ball bearings from Quality Bearing & Components - QBC feature glass or stainless steel balls arranged in single and double row construction. Identified as the BBPRIX-... and BBPRIXM... Series, they are stocked in both inch and metric sizes. They are designed to fit shafts ranging from 3/16" to 1" (5 mm to 25 mm) diameters. Their dynamic load ratings range from 17 lbs. to 127 lbs. (58 N to 565 N). These bearings are excellent for washdown, and corrosive environments. These bearings incorporate acetal raceways. These economically priced bearings are widely used for light-duty applications. Quotes plus online orders are available at the new QBC eStore.
QBC has in stock: miniature bearings, plastic bearings, rod end bearings, spherical bearings, pillow blocks, sintered bronze bushings, radial ball bearings, thrust bearings & washers, sleeve bearings, needle bearings, inner races, roller clutches, guide wheels & rail systems, linear ball bearings, inner and outer ring spacers and shafting. QBC stocks both inch and metric sizes. New to the Web site is our eStore which allows you to check price and availability, place an order or request a quote anytime. QBC also provides custom-made bearings and shafting to the customer print. We also offer on-site relubing of bearings in a certified class 1000 clean room.
Detailed technical specifications are contained in catalog B620 available free upon request from Quality Bearings & Components - QBC. This catalog can be viewed now, in .PDF format, and downloaded by section on the Web at: www.qbcbearings.com, or via mail request.
Buy it: http://www.qbcbearings.com/Buy/BallBearings.htm#Thin
View catalog page: http://www.qbcbearings.com/B620/HTML/048.html
Request catalog: https://qbcbearings.com/qbc_orderusa.htm
