Industry News Materials
OnlineMetals.com Introduces Custom-Cut Option on Machine-Ready Blanks by TCI Precision Metals
OnlineMetals.com introduces Custom-Cut Precision Machine-Ready Blanks from TCI Precision Metals. Custom-Cut blanks let customers order materials that are as close as .002” to their desired dimensions.
“Precision Machine-Ready Blanks available through OnlineMetals.com are pre-configured in more than 200 dimension/alloy combinations. Each blank ships flat, square, parallel, and +/-.002" of stated dimensions. Even with so many pre-machined blanks to choose from, the customer's dimensional requirements often fall between standard available sizes. Now they can order the custom-cut option and get exactly what they need. This is important, especially when customers want to go directly from receiving to machining without any further prep,” said Ben Belzer, president and CEO of TCI Precision Metals.
Ready-to-ship blanks help shops shorten setup time, reduce scrap, and increase overall throughput by up to 25 percent by eliminating material prep. Blanks arrive machine-ready for production and are ideal for short-run and production machining, tooling and prototype applications.
Precision blanks eliminate the need for in-house sawing, grinding, flattening, and squaring operations, as well as outside processing. Blanks are consistent, part-to-part, which reduces setup time. In the case of flat blanks, the production process alleviates residual stress in the material, which results in reduced part movement during finish machining. Each blank is deburred, cleaned and individually packaged to avoid damage during shipping.
Precision ground Machine-Ready Blanks from OnlineMetals.com ship in one to three days. Standard and custom-cut sizes are precision ground on either 2 sides or 6 sides, or precision saw cut, depending on the material:
2-Sided Precision Ground Blanks
Each blank is precision ground or milled on both sides to a thickness tolerance of +/-.002˝. Width and length for aluminum are saw cut to +.063-0˝. The width and length for stainless steel are saw cut or waterjet cut to +.125-0˝.
•    Aluminum
•    Alloy Steel
•    Copper
•     Carbon Steel
•    Stainless Steel
2-Sided Round Precision Ground Blanks
Each blank is precision ground to +/-.002˝ on thickness; diameter based on stock.
2-Sided Aluminum Strip Blanks
Thickness based on stock; saw cut to +.063-0˝ on width and length.
6-Sided Precision Ground Blanks
Each blank is precision-ground or milled on both sides for thickness and on all four sides for width and length. All dimensions +/-.002˝.
•     Aluminum
•     Stainless
•    Alloy Steel
tciprecision.com
