Oilgear Expands Variable Displacement Pump Series
A new range of variable displacement pumps has been launched to the EMEA market as a result of a multi-million pound investment made by Oilgear to its manufacturing facilities. The new range of axial piston pumps complement Oilgear’s existing product range and add greater flexibility and efficiency for the company’s market leading, bespoke electro-hydraulic packages; suitable for industries as diverse as construction, marine and defense.
Oilgear’s variable displacement, axial-piston pumps are well known for offering reliable, long lasting performance in some of the harshest operating conditions on the planet. Having invested in a fully automated production plant at its manufacturing facilities in Fremont, Nebraska, it is now able to offer a larger range of products than ever before; with exceptionally low lead times on all orders globally, even on non-standard orders.
The range of performance capabilities within the range is vast, truly offering a solution for almost any application from mobile plant equipment through to steel forging presses. The accuracy and reliability of the pumps allow them to integrate seamlessly with larger hydraulic systems and improve the overall efficiency of the package. Their compact design makes them easy to retrofit to existing packages to deliver the same benefits to applications where the hydraulic system is midway through its service life.
Kieran Doyle, managing director for Oilgear UK, comments: “The Oilgear range of hydraulic piston pumps uses advanced manufacturing techniques to reduce wear internally and extend the overall service life – making them some of the most durable pumps on the market. Available as part of our bespoke engineered packages or as individual components from any of our licensed distributors, we’re able to use the new range to respond quickly to our customer’s needs with short delivery times and top class reliability.”
