Oilgear Exhibits Pump Packages at Bauma 2016
With almost 100 years of manufacturing expertise, Oilgear products are well known for offering reliable performance in some of the harshest industries on the planet. Its experience in industries such as construction and mining has given its engineers an intrinsic understanding of the unique challenges of designing hydraulic packages for use in dusty environments, where the work load is heavy and the tolerance of unreliability is non-existent.
Oilgear is already a supplier to leading mobile plant OEMs, offering a wide selection of pump designs ranging in size and suitable for many niche applications. Its range of PVV and PVG variable displacement pumps are some of the most reliable on the market, with large performance windows which suit almost any application.
All these pumps can be packaged with custom valve and manifold designs to create a truly bespoke, engineered solution. As a result, Oilgear is able to offer a more flexible service than many larger manufacturers. Its engineers have intimate knowledge of its components and will design a solution from the ground-up that meets very specific requirements.
Visitors to Bauma this week will have the opportunity to speak to Oilgear’s engineers about their specific requirements and learn more about the company’s manufacturing and engineering expertise, which has made it the supplier of choice for many leading figures in construction and mining.
