Gear Drives Product News
NORD Offers Universal Motor Series
NORD has introduced its new Universal Motor, with 20 models in the range extending from 0.12 to 45 kW power.
The NORD Universal Motor is certified to CE, UL, CSA, CCC, ISI and EAC and meets appropriate minimum efficiency levels to ensure suitability for markets that include Europe, United States, Canada, Russia, China, India and others. The motor is also certified to Bureau Veritas for marine and offshore applications. The 3-phase NORD Universal Motor can be used with four standard voltage supplies noted on the motor nameplate: 380 V 50 Hz, 400 V 50 Hz, 415 V 50 Hz, and 460 V 60 Hz, additionally however it can also be used at 440 V 60 Hz and 480 V 60 Hz.
Available in 4-pole configuration, the robust motors suit IEC frame sizes from 63 to 225, they are available in B3 foot, B5 flange or B14 face mounting and to suit the US market it can be supplied as NEMA C-face and NEMA foot mount. The motor can also be directly mounted to NORD gearboxes providing a compact and more efficient drive solution.
As standard the motor is protected to IP55 is Totally Enclosed Fan Cooled TEFC and Class F Insulation.
Other options available for the NORD Universal Motor include quick connectors, single or double protection canopies, space heater, spring applied brake and forced ventilation. If required, the motor enclosures can also be provided in IP66 rating, which means they are dust tight and protected against heavy seas or powerful jets of water.
The new range of energy-efficient, high-quality Universal Motors from NORD is available now.
