NKE Introduces New Ball Bearings
NKE introduced its new range of single row deep groove ball bearings. The new NKE POP range of single row deep groove ball bearings offers reduced running noise,longer lubricant service life, and a low starting torque. According to the company's press release, the new deep groove ball bearings are subject to stringent, documented quality inspections as well as 100 percent noise testing. The low running noise is achieved through the use of a new type of lubricant, which also minimizes the bearing's starting torque even at low operating temperatures. The lubricant has a service life from -50 to 150 degrees C. Bearings feature a pair of double-lipped labyrinth seals, which protect from contamination and improve grease retention in spite of the low friction. The bearings' raceways have an enhanced surface finish. The new POP range of single row deep groove ball bearings is available from stock in the size ranges 6000 to 6012, 6200 to 6212, and 6300 to 6310, with bore diameters from 10 mm to 60 mm or 50 mm, in open version, 2RS2 version (sealed with two synthetic rubber seals) and 2Z version (sealed with two steel shields) and with clearances CN (standard) and C3.
