NFPA Releases New Technical Standards
The National Fluid Power Association (NFPA) has recently released seven new technical documents that are available for purchase including: ISO 10041-1:2010: "Pneumatic Fluid Power-Electro-Pneumatic Continuous Flow Control Valves-Part 1: Main characteristics to include in the supplier's literature"; ISO 10041-2:2010: "Pneumatic Fluid Power-Electro-Pneumatic Continuous Flow Control Valves-Part 2: Test methods to determine main characteristics to include in the supplier's literature"; ISO 10094-1:2010: "Pneumatic Fluid Power-Electro-pneumatic pressure control valves-Part 1: Main characteristics to include in the supplier's literature."; ISO 10094-2:2010: "Pneumatic Fluid Power-Electro-pneumatic pressure control valves-Part 2: Test methods to determine main characteristics to include in the supplier's literature"; ISO 19879:2010: "Metallic tube connections for fluid power and general use-Test methods for hydraulic fluid power connectors."; NFPA/T3.6.8 R3-2010: "Fluid Power Systems-Cylinders-Dimensions for accessories for cataloged square head industrial types"; NFPA/T3.6.37 R1-2010: "Hydraulic Fluid Power-Cylinders-Methods for determining the buckling load."
