Next Steps in Artificial Intelligence
Representatives from Mercedes, Siemens, Beckhoff, Arburg, Hawe, KSB and Sick, among others, spent three days this summer discussing the relationship between humanoids and AI, the revival of reinforcement learning and AI utilization. As AI implementation becomes easier for manufacturers, the focus is evolving to address challenges and new opportunities across the entire industrial sector.
Intelligent Robots/Intelligent Bodies
Hannover Messe reports that several robots are already performing many AI tasks today. While the software is becoming ever more powerful, the mechanical construction (the body, for example) often falls by the wayside. Edoardo Milana, junior professor of soft machines at the University of Freiburg, advocates a paradigm shift: away from rigid machines and towards flexible, body-intelligent robots.
One example: four-legged robots, so-called quadrupeds, need around 300 watts to move around. A real dog, on the other hand, only needs 30 watts—with significantly more complex movements. The reason lies in nature itself: Biological bodies use their mechanical properties to perform movements efficiently and flexibly.
Milana emphasizes the importance of “embodied intelligence,” a concept from philosophy and psychology that states that intelligence is not only anchored in the brain, but also in the body. For robotics, this means that the body of a robot should not just be passively controlled by the software but should actively contribute to intelligence.
A robot that can adapt to its environment requires less central computing power and energy. This allows resources to be used for more complex tasks such as planning and perception.
Milana’s research focuses on soft robots/machines made of soft, flexible materials, inspired by simple and aquatic organisms.
