Nexen Introduces Complete Geared Bearing Solution
Nexen Group, Inc. introduces a complete Geared Bearing solutions based on their innovative Roller Pinion System (RPS).  The new Geared Bearing package comes complete with a zero backlash gear mounted and dialed in on a precision grade high capacity bearing. Nexen’s Geared Bearings are available in a wide variety of sizes and gear ratios, and preconfigured for fit, form and function, for easy integration into any precision rotary motion application.
Nexen’s new Geared Bearing Product Selector tool makes it quick and easy to select the gear needed. Customers simply adjust online sliders for torque, gear O.D. size, accuracy and gear ratio requirements. The tool instantly shows all the options that fit. OEMs also have easy access to STEP files and specifications. Nexen holds bearings in inventory and gear raw material on hand, so bearings are available for fast delivery.
