New Waterproof Lift-Lever Pull Handles from aMsp Eliminates Difficulties Typically Caused by CAM Resistance
All Metric Small Parts — aMsp a leading provider of metric hardware components, announced the availability of the MAKT31M1THA505... Series of lift-lever pull handles that have an added waterproofing, making them ideal for use in outdoor applications or applications in a damp or wet climate. These cylindrical lock-type handles can be ordered with or without a key option. All three sizes, that range in length from 86 mm to 142 mm and have widths of 28 mm to 32 mm, can be used for both left and right side applications, simply by changing the position of the CAM. Uses for these pull handles include distribution boards/panels, control boards, telecommunication devices, office automation appliances and marine environments. The key can be made for either locked or unlocked positions if requested.
3-D CAD models are available for download at the aMsp Web site. The aMsp online eStore allows you to choose from a great selection of additional lift-lever pull handles, control knobs, knurled knobs, dimpled knobs, wing knobs, triangular, scallop knobs, spherical knobs, and many more. You can browse the knob selection and buy 24 hours a day, 7 days a week. aMsp offers an extensive selection of all Metric standard industrial machine components. Their products include: Knobs, Door Latches, Panel Latches, Cabinet Latches, Boat Latches, Pull Handles, Handwheels, Cranks, Grips, Levers, Locks, Catches, Hinges, Screws, Washers, Springs, Keys, Plungers, Pins, Leveling & Support Feet. All of these products are 100% RoHS Compliant.
